10 years agoChange between boards.
Hello everyone, I am out of ideas for fixing my issue so i hope some of you will can help me to. I am using the hmc-dvi from terasic board with two development kits. I made a design that just ...
10 years ago --- Quote Start --- Have you got a design that fully meets timing in both boards? have to got the correct timing specs for both? is it a fully synchronous design? --- Quote End --- After testing the timing requirements, found out that 3 of the rx data lines have a really big delay because their input and output are too far away. I cannot change the pins themselves.. Any simple way to syncronize the outputs ? I can live with all signals equally delayed...
