13 years agoCar Park Indicator System
i need to design a car park indicator system for a space with 8 lots. it needs to have the following specifications: a seven-segment display to indicate the number of free lots. presettable...
13 years ago --- Quote Start --- Finally I give you a tip: Use tabs to line your code. As you start a block (if, begin, port, etc.) you use a tab on the next line, this improves reading and thereby you can easily find problems related to errors like 10500. --- Quote End --- that was because the forum strips out leading whitespace unless you use code tags.
