13 years agoCar Park Indicator System
i need to design a car park indicator system for a space with 8 lots. it needs to have the following specifications: a seven-segment display to indicate the number of free lots. presettable...
13 years agoYou should check the second error first. in this case I think it is also the cause of at least the first error.
ad in the process you start with an elseif, you should start with an if statement. I suggest reading chapters (or search the web) about the if statement. Also you should take a look at how to open and close entities and architectures. Finally I give you a tip: Use tabs to line your code. As you start a block (if, begin, port, etc.) you use a tab on the next line, this improves reading and thereby you can easily find problems related to errors like 10500.
