15 years agoCan't use the alt_signaltap_run with matlab on a windows 7 machine (64 bits)
I have this strange problem. I'm trying to use the alt_signaltap_run to capture data from signaltap into matlab. I have done it successfully in the past up until I got a new computer with windows 7...
15 years agocodina,
I have found a (temporary) solution. Simply download the r2010a (or whatever version) for a 32 bit machine. When downloading, you are asked to select between a 32bit or 64bit version. It will automatically install it in Program Files (x86) instead of Program Files if you have Windows 7. The problem will then go away. Just make sure you click on the correct (32 bit) executable to start matlab, in case you have them both installed on your machine.
