8 years agoCan't scan JTAG chain - DE0-CV / Win 10
Hello all, I have purchased my first FPGA recently it is a DE0-CV. I cannot get my computer to access it via JTAG. I am using Windows 10. - I have tried to use the DE0-CV Control Panel s...
8 years agoI have tried .JIC, .SOF, .POF. I disabled my firewall and I have no antivirus on the current dev machine.
When I try .SOF from the DE0-CV 'cd'. I put the device in PROG reset it. The leds go dim like they are supposed to. I change the mode in programmer to Active Serial. Select the EPCS64 device. When I click start it says "Error (209025): Can't recognize silicon ID for device 1. A device's silicon ID is different from its JTAG ID. Verify that all cables are securely connected, select a different device, or check the power on the target system. Make sure the device pins are connected and configured correctly." Note: the usercode is 00000000 when I try this. also when I push start the ULED flashes one time and then the software throws an error
