OTser
6 years agoCan't recognize silicone ID on EPCS64
I am using Dallas Logic's CMC1003 module http://dallaslogic.com/prod_cmc1003/ and it has stopped accepting data through the ASMI port, instead returning the titular error. The module somehow still wo...
YuanLi_S_Intel
6 years agoHi Oleg,
Apologize that we are not familiar with Dallas's board and setup. But anyhow, we will still try to help as much as we could. When you said about stopped accepting data through the ASMI port. Does it work previously? If it is, probably you may debug by probing the ASMI port and see if signal is flowing through correctly or not. If not, that means the hardware is having problem.
Also, you may seek for their help to try to restore the board to default bitstream and setting. Hope it helps.
Thank You.
