15 years agoCan't config the cyclone ii EP2C20Q240
Hi guys, I'm a student learning FPGA,I bought a cyclone ii EP2C20Q240 and want to download a program .But it doesn't work. THE 50MHZ crastal to the chip is ok, and the chip's vcc and gnd is al...
15 years agoIf there is no need to give external power supply then you made enough connections.No need to have more connections.
check that driver for that download cable installed succesfully and make sure that in hardware configuartion u selected your proper hardware like "use-blaster" or anything that you are using.
