15 years agoCan't build hello world sample project based on tutorial
Hi all, I recently purchased a DE0_NANO FPGA Board, and was trying to build a ''hello world'' project by following the tutorial step by step. But some weired errors occured during the proc...
15 years ago --- Quote Start --- since, you might not have license for Quartusii and niosii You can not build permanent module of *.sof. But time limited must work in same way as long as the time limited dialog is shown when you download the sof file. Do not cancel the dialog. Also if you change your NiosII into NiosII/e. you can get normal sof as you guessed. good luck. --- Quote End --- I tried all the three versions of NIOS II microprocessors. None of them worked. I cannot successfully build the "hello_world " prject.
