Rmc_Arira
6 years agoCan't access Jtag error
I am using a MAX 10 device: 10M04SCU169C8G
I used Quartus 17.0 to synthesize and build the FPGA
I have tried using the stand alone programmer versions 17 and 18.
I have tried two different byt...
NurAiman_M_Intel
6 years agoHi,
CRC-Error open drain has dual purpose pin which are pull up(enable) and pull down(disable). Intel recommends you to tie the CRC_ERROR pin to VCCIO, GND, or leave the pin unconnected when the CRC error detection circuitry is disabled or when you are not using the CRC_ERROR pin.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/max-10/PCG-01018.pdf
You can try to go to Quartus -> Convert programming file -> Advance -> Tick both boxes ( Disable EPCS and disable AS mode).
Aiman
