15 years agoCannot work
Firsr I built a project includes Nios II ,memories ,it works. When I added a DDR2 SDRAM controller, not only the DDR2 does't work but also the system . The pin assignment has been finished. Wh...
15 years agoIt depends on your design. If you have a reset button and it has the correct polarity, try connecting it. Or you can connect it to a bit of a PIO if you want the system to self reset.
If these signals are active high while the reset_n is active low, put a NOT gate. I think that someone else, just yesterday, had a similar problem and went around it stucking the reset_n to high level (a signal fixed to '1' or a VCC primitive in bdf file)
