15 years agoCannot work
Firsr I built a project includes Nios II ,memories ,it works. When I added a DDR2 SDRAM controller, not only the DDR2 does't work but also the system . The pin assignment has been finished. Wh...
15 years agoYou do not use it, fine. I am quite sure that with the altmemphy based DDR2 controller, a reset_n signal appears in the SOPC Builder. It may appear even with the uniphy based controller (never used it). Are you sure this reset is correctly connected? If left floating or grounded it may give a reset to the controller, I am not sure that the controller while in reset do not asks for a system reset.
