Cannot merge HSSI Avalon Memory-Mapped interface instances for simplex JESD designs
For your information, I have created a simple test design with simplex JESD204b TX and RX PHY only with dynamic reconfiguration enabled. I was able to merge both into the same XCVR channel. Attached is the QAR for your reference. Note that I am using PHY only to ease the demo.
For your information, you should take note that you cannot merge if you have the following enabled:
1. ADME
2. Shared reconfig interface
3. Capability registers
I believe you cannot enable the Control and status registers and PRBS soft accumulators as well but I could not be sure on these two. You may further test out if you need these.
Thanks for your message, but still no success.
I did find this explanation on the error message here as well
which is quite similar.
My flow uses tcl scripts, and when I write out the .tcl file for IP generation during the build phase, the only options I see are the following:
set_instance_parameter_value jesd204_0 {TEST_COMPONENTS_EN} {0}
set_instance_parameter_value jesd204_0 {bitrev_en} {0}
set_instance_parameter_value jesd204_0 {bonded_mode} {non_bonded}
set_instance_parameter_value jesd204_0 {gui_analog_voltage} {1_0V}
set_instance_parameter_value jesd204_0 {gui_user_crete_tile} {etile}
set_instance_parameter_value jesd204_0 {lane_rate} {9830.4}
set_instance_parameter_value jesd204_0 {pll_reconfig_enable} {0}
set_instance_parameter_value jesd204_0 {pll_type} {CMU}
set_instance_parameter_value jesd204_0 {rcfg_enable_split_interface} {0}
set_instance_parameter_value jesd204_0 {rcfg_jtag_enable} {0}
set_instance_parameter_value jesd204_0 {rcfg_shared} {0}
set_instance_parameter_value jesd204_0 {sdc_constraint} {1.0}
set_instance_parameter_value jesd204_0 {set_capability_reg_enable} {0}
set_instance_parameter_value jesd204_0 {set_csr_soft_logic_enable} {0}
set_instance_parameter_value jesd204_0 {set_prbs_soft_logic_enable} {0}
set_instance_parameter_value jesd204_0 {set_user_identifier} {0}
set_instance_parameter_value jesd204_0 {wrapper_opt} {base_phy}
set_instance_property jesd204_0 AUTO_EXPORT true
and they are all disabled...But it still shows the error message.
I also saw that your design only has 1 JESD lane, my design has 2 lanes...could that be interfering as well?
