Cannot merge HSSI Avalon Memory-Mapped interface instances for simplex JESD designs
Sorry for the delay. Thanks for sharing the designs. Please allow me some more time to debug into this. Please ping me if you do not hear from me by end of the week.
For your information, I have created a simple test design with simplex JESD204b TX and RX PHY only with dynamic reconfiguration enabled. I was able to merge both into the same XCVR channel. Attached is the QAR for your reference. Note that I am using PHY only to ease the demo.
For your information, you should take note that you cannot merge if you have the following enabled:
1. ADME
2. Shared reconfig interface
3. Capability registers
I believe you cannot enable the Control and status registers and PRBS soft accumulators as well but I could not be sure on these two. You may further test out if you need these.
- cheyert5 years ago
Thanks for your message, but still no success.
I did find this explanation on the error message here as well
which is quite similar.
My flow uses tcl scripts, and when I write out the .tcl file for IP generation during the build phase, the only options I see are the following:
set_instance_parameter_value jesd204_0 {TEST_COMPONENTS_EN} {0}
set_instance_parameter_value jesd204_0 {bitrev_en} {0}
set_instance_parameter_value jesd204_0 {bonded_mode} {non_bonded}
set_instance_parameter_value jesd204_0 {gui_analog_voltage} {1_0V}
set_instance_parameter_value jesd204_0 {gui_user_crete_tile} {etile}
set_instance_parameter_value jesd204_0 {lane_rate} {9830.4}
set_instance_parameter_value jesd204_0 {pll_reconfig_enable} {0}
set_instance_parameter_value jesd204_0 {pll_type} {CMU}
set_instance_parameter_value jesd204_0 {rcfg_enable_split_interface} {0}
set_instance_parameter_value jesd204_0 {rcfg_jtag_enable} {0}
set_instance_parameter_value jesd204_0 {rcfg_shared} {0}
set_instance_parameter_value jesd204_0 {sdc_constraint} {1.0}
set_instance_parameter_value jesd204_0 {set_capability_reg_enable} {0}
set_instance_parameter_value jesd204_0 {set_csr_soft_logic_enable} {0}
set_instance_parameter_value jesd204_0 {set_prbs_soft_logic_enable} {0}
set_instance_parameter_value jesd204_0 {set_user_identifier} {0}
set_instance_parameter_value jesd204_0 {wrapper_opt} {base_phy}
set_instance_property jesd204_0 AUTO_EXPORT trueand they are all disabled...But it still shows the error message.
I also saw that your design only has 1 JESD lane, my design has 2 lanes...could that be interfering as well?
