Cannot generate pcie avmm example design
- 3 years ago
Hi Allen,
that is limitation of Window OS,
As previous reply, you can try to generate the example design in Linux OS and use it in Windows OS.Let me know if there is anything else I can help you.
Regards,Wincent_Intel
Hi, wchiah
I'm sorry, my computer browser had some issues earlier,The device I am using is Stratix 10-1SX110HN2F43I2VG
I follow your .ip configuration, I am able to generate the design example using Quartus v22.3
I have attached the .qar file to you for reference.
Wincent_Intel
- allen183 years ago
Can you please try enabling this limitation and see if it produces the same error as mine? since my computer is owned by the company, I am unable to modify certain configurations.
- Wincent_Altera3 years ago
Hi Allen,
Hi Allen,
Thanks for confirming the answer, glad that I am able to help you.
Hence, This thread will be transitioned to community support.
If you have a new question, feel free to open a new thread to get support from Intel experts.
Otherwise, the community users will continue to help you on this thread. Thank you
If your support experience falls below a 9 out of 10, I kindly request the opportunity to rectify it before concluding our interaction. If the issue cannot be resolved, please inform me of the cause so that I can learn from it and strive to enhance the quality of future service experiences.
Wincent_Intel
Thank you very much. I have indeed tried multiple times but failed to generate it. I searched for the reason and it could be due to the Maximum Path Length Limitation. Does your Windows have a limitation of MAX_PATH = 260?
Hi Allen,
You may look at the solution as belowhttps://www.intel.com/content/www/us/en/support/programmable/articles/000087662.html
Yes, you are right This issue is possible caused by filename length limitation of Windows OS. You can generate the example design with Linux OS, which can be used on Windows OS as well. Or you can try with the following workaround on Windows OS. Thanks.
https://docs.microsoft.com/zh-cn/windows/win32/fileio/maximum-file-path-limitation?tabs=cmd
