Cannot generate pcie avmm example design
- 3 years ago
Hi Allen,
that is limitation of Window OS,
As previous reply, you can try to generate the example design in Linux OS and use it in Windows OS.Let me know if there is anything else I can help you.
Regards,Wincent_Intel
You should click the "Reply" before you can post the "Post Reply"
Can you please provide me the device OPN ? I will try to replicate this on my place and see if I can see the same error as yours or not.
Wincent_Intel
Hi, wchiah
I'm sorry, my computer browser had some issues earlier,The device I am using is Stratix 10-1SX110HN2F43I2VG
- Wincent_Altera3 years ago
I follow your .ip configuration, I am able to generate the design example using Quartus v22.3I have attached the .qar file to you for reference.
Wincent_Intel
- allen183 years ago
Can you please try enabling this limitation and see if it produces the same error as mine? since my computer is owned by the company, I am unable to modify certain configurations.
Hi Allen,
Thank you very much. I have indeed tried multiple times but failed to generate it. I searched for the reason and it could be due to the Maximum Path Length Limitation. Does your Windows have a limitation of MAX_PATH = 260?
Hi Allen,
You may look at the solution as belowhttps://www.intel.com/content/www/us/en/support/programmable/articles/000087662.html
