AGaru1
6 years agoCannot generate Intel Avalon-MM Intel Stratix 10 Hard IP+ for PCI Express design example on Quartus Prime Pro 19.4.
After clicking generate example design: Info: avmm_bridge_512_0: Auto-generation of QSYS example design beginning... Info: avmm_bridge_512_0: Validating example design parameters and selection... ...
BoonT_Intel
6 years agoHi Sir,
What is the setting that you apply when generating the example design? I am using default setting (open a new IP GUI and generate the example design without change the setting), and I am able to generate the example design. See attached screenshot.
Also, are you able to generate the same example design if you are using other quartus version?
