15 years agoCan VREF be other than VCCIO/2?
Must VREF be equal to 1/2*VCCIO, or can it be, say, 2/3*VCCIO? BTW, I'm using a Cyclone III M164 package. (very small physical board constraints) I'm trying to interface to a chip that has...
15 years agoShorted outputs are the most popular reason for excessive current consumption, I would check the pinout file against the schematic in a first step. Also check all supply voltages and - if possible - determine which supply pins are sinking high current.
If it's your own PWB, also wiring and solder faults should be considered.
