15 years agoCan i deserialize LVDS using DCFIFO ?
Hi, I am wondering if i could deserialize a LVDS signal using a DCFIFO block ? I've tried numerous method, but no success. Michael
15 years ago --- Quote Start --- Do you think i can use the altlvds_rx at deserialize factor of 6, then go through a DCFIFO to get 12 bits? --- Quote End --- Yes, that should be possible. You could also do 1:8, and store 3 x 8-bit values, and write it into 24-bit RAM, then read out 24-bits, and output two consecutive 12-bit values. Cheers, Dave
