15 years agoCan i deserialize LVDS using DCFIFO ?
Hi, I am wondering if i could deserialize a LVDS signal using a DCFIFO block ? I've tried numerous method, but no success. Michael
15 years ago --- Quote Start --- I am wondering if i could deserialize a LVDS signal using a DCFIFO block ? I've tried numerous method, but no success. --- Quote End --- No, not really. You might be able to perform a 8-bit to 16-bit width change or something like that, but that would not technically be deserialization then would it :) What are you trying to do? Did you try to use the altlvds_rx component? Here's an example of LVDS deserialization at 1Gbps http://www.ovro.caltech.edu/~dwh/carma_board/digitizer_tests.pdf Cheers, Dave
