13 years agoCan DMA do NOT use a same clock with PCIe IP when using Cyclone IV GX?
If I use a PCIe IP with Qsys,and use DMA mode to transfer video data to our ARM SOC. Can DMA IP use a different clock compard with PCIe IP? If so,When I write,for example,512 bytes to PCIe Tx...
13 years agoAnd it seems that I understand.
In the PCIe IP spec, the part which describe the interface of PCIe IP help me understand the details of Avalon-MM transferring. Combining your reply and the PCIe IP spec,I think I understood. I use the altera hard PCIe IP. Thank you very much.akira.
