13 years agoCan cyclone III comes into the user mode if AP config failed?
Original tille: "Can cyclone III comes into the user mode if AP config failed?" I can't find the EP3C120F780I7N when scan the JTAG chain. I want to kown what happend when nSTATUS and CONF_...
13 years agoI'm not aware of the term "POR error" used anywhere in the Altera documentaion, nor can I read a reasonable meaning into it. What do you mean?
If you're referring to a state where POR isn't released, check all power supplies that are monitored by the POR circuit as well as the device soldering, as already suggested by Daixiwen. nCONF held permanently low (with proper pull-up) suggests in fact active POR, also inaccessible JTAG.
