10 years agoCan an FPGA partially fail? (EPM7128SLI84-10)
Hi All, I have a production run of 110 plug in modules that each use a single EPM7128SLI84-10, two of these devices are suspected of failing as the modules show exactly the same fault in that 8...
10 years agopartial failure may result from timing margin issues. If the problem is at powerup then I will also suspect some floating inputs. Try touching the area of chip and see effect but beware of static damage.
