13 years agoCan Altera FPGA support DDR2 or DDR3 interchangable memory of PC?
I want my board to support DDR2 or DDR3 PC memory through standard memory slot. The FPGA should support most kinds of memory in stock. However when I tried to config DDR2 or DDR3 memory contr...
13 years ago --- Quote Start --- Does the IP core altera supplied will allow programmable parameters? --- Quote End --- Read the manual, create and instance of the component, and simulate it. Sorry, I can't do your job for you. Also, I haven't used this core, so I don't know the answer :) Cheers, Dave
