Calculate skew timing with Cyclone V and ksz9031
hello,
i have troubles with the ethernet bandwith and retransmissions (ack). after some diagnostic i think it is an timing issue.
the wire length from the fpga -> knz9031 is:
| mil | mm | m | delay | delay | |
| RX_DV | 1692,83 | 42,997882 | 4,30E-02 | 227,5E-12 | 228ps |
| RX_CLK | 1649,35 | 41,89349 | 4,19E-02 | 221,7E-12 | 222ps |
| RXD0 | 1684,72 | 42,791888 | 4,28E-02 | 226,4E-12 | 226ps |
| RXD1 | 1648,24 | 41,865296 | 4,19E-02 | 221,5E-12 | 222ps |
| RXD2 | 1681 | 42,6974 | 4,27E-02 | 225,9E-12 | 226ps |
| RXD3 | 1677,12 | 42,598848 | 4,26E-02 | 225,4E-12 | 225ps |
| TX_EN | 1625,87 | 41,297098 | 4,13E-02 | 218,5E-12 | 219ps |
| GTX_CLK | 1629,75 | 41,39565 | 4,14E-02 | 219,0E-12 | 219ps |
| TXD0 | 1633,94 | 41,502076 | 4,15E-02 | 219,6E-12 | 220ps |
| TXD1 | 1657,65 | 42,10431 | 4,21E-02 | 222,8E-12 | 223ps |
| TXD2 | 1657,33 | 42,096182 | 4,21E-02 | 222,7E-12 | 223ps |
| TXD3 | 1655,12 | 42,040048 | 4,20E-02 | 222,4E-12 | 222ps |
all wires are the same length, in every wire is an 22r resistor. the design is bought and not designed by us.
i found the following knowledge base entry:
https://www.intel.com/content/www/us/en/support/programmable/articles/000079123.html
=> TX_CLK to TXD/TX_CTL output data delay is specified as -0.85 to 0.15 ns
Datasheet 9031:
For the receive path (KSZ9031RNX to MAC), the KSZ9031RNX adds 1.2 ns typical delay to the RX_CLK output pin, with respect to RX_DV and RXD[3:0] output pins.
We use kernel v4 with u-boot and devicetree, after a lot of measuring and test,
i got the best result with this skew timing:
&gmac1 { status = "okay"; phy-mode = "rgmii"; /* 0 bis 900*/ rxd0-skew-ps = <420>; rxd1-skew-ps = <420>; rxd2-skew-ps = <420>; rxd3-skew-ps = <420>; rxdv-skew-ps = <420>; txd0-skew-ps = <360>; txd1-skew-ps = <360>; txd2-skew-ps = <360>; txd3-skew-ps = <360>; txen-skew-ps = <360>; /* 0 bis 1860*/ rxc-skew-ps = <1680>; txc-skew-ps = <1740>; max-frame-size = <3800>; };
But how could i calculate the skew timing?
Which timing should be the best, with mathematics
- Nurina
I'm still waiting for a response from our internal team regarding the calculation. I'll let you know once I receive updates.
Nurina
- Nurina
Also, may I know where are you adding these skew timing code? Is this directly applied to the KSZ9031 to adjust the skew?
- qwitza
we change the skew time in the device tree.
i think that it is applied, because the transfer speed and the retransmission error change with.
thanks a lot
- Nurina
As far as I know, connecting it to an oscilloscope would be easiest. The calculation could be quite difficult.
Let me get back to you on the calculation method.
Nurina
- qwitza
hi,
but it have to be possible to calculate the best timing,
or have i use really an oscilloscope for the timing?
our oscilloscope is too slow, for that speed
- Nurina
Thank you for using Intel Communities.
Please allow some time while I investigate your case.
Nurina
