qwitza
3 years agoCalculate skew timing with Cyclone V and ksz9031
hello,
i have troubles with the ethernet bandwith and retransmissions (ack). after some diagnostic i think it is an timing issue.
the wire length from the fpga -> knz9031 is:
mil
Nurina
3 years agoHello,
Can you provide some updates?
I cannot get any confirmation with internal team on the best skew calculation.
But the normal practice is to start with measuring a working window, get the min and max skews then use the midpoint and fine tune it as you wish. I think you have done this already.
If it is working on the hardware then it should be fine.
Nurina
- qwitza3 years ago
hello,
but how about the wire length?
sould be the resistor considered?
how would be the "best" timing for our board?
thanks
