15 years agoC4gx dev kit and TSE
Hello all, I work on C4GX dev board, I use the board update portal design exemple and I use Simple Socket server on my NIOS application. First I've worked with the subscription version (3...
15 years agothanks for your help,
But If I compare the .sdc files from altera folder and the .sdc from my project, they are the same. I downloaded and install the board_update_portal project exemple made with quartus v11 on altera web site. When I recompile the project without any changement It works. The I rename PIO_LED into PIO_LED_TEST and It doesn't work. Then If re-rename into PIO_LED it doesn't work too. I think I will continue using SOPC builder. thanks. Someone know I can use on-chip memory insted of ssram ??
