15 years agoC4gx dev kit and TSE
Hello all, I work on C4GX dev board, I use the board update portal design exemple and I use Simple Socket server on my NIOS application. First I've worked with the subscription version (3...
15 years agoDo you have a top level .sdc that gives at least the frequencies of your clock inputs, and the derive pll instruction?
In the timequest report you can have a look at the clocks list and check if your clocks are listed there, with the correct frequencies. Check also during compile that you don't have a "does not meet timing requirements" critical warning.
