15 years agoC4gx dev kit and TSE
Hello all, I work on C4GX dev board, I use the board update portal design exemple and I use Simple Socket server on my NIOS application. First I've worked with the subscription version (3...
15 years agoHi,
Thanks for the reply and for your ideas. I use system id and I verify it, it's OK. I'am programming with the time_limited.sof. I think like you that It could be a timing problem. Maybe I don't add a .sdc in my quartus but when I check I have the tse_mac_constraints.sdc. I made a test, I copy the altera original project and I copy it. I compile it with quartus to create the time_limited.sof. I program it and run my own SSS application in NiOS. And It works. But If I made any change in my nios (add PIO or rename...) after I can't run my application it always fail at at "INFO : PHY[0.0] - Auto-Negotiation PASSED". thanks.
