16 years agoC2 & C3 AS Mode EPCS without Altera EPCS IP
All Cyclone 1, 2 and 3 designs i have done with EPCS devices for AS configuration used the EPCS controller ip that is provided by the sopc builder with the nios cpu. now i do a design that uses...
16 years agoYou should use the ALTASMI_PARALLEL megafunction described at http://www.altera.com/literature/ug/ug_altasmi_parallel.pdf
Connection info and tips: http://www.alteraforum.com/forum/showthread.php?t=20967 You can simulate it: http://www.alteraforum.com/forum/showthread.php?t=20899 It works fine, but you should beware that Altera does not provide timing models. So help me out here: http://www.alteraforum.com/forum/showthread.php?t=20938 (http://www.alteraforum.com/forum/showthread.php?t=20967)
