16 years agoC code question !! / NIOS II / SPI interface
Hello, I have a question about implementing the spi interface in a FPGA, I already constructed a working CPU with a implementation of the SPI, and added the correct settings in SOIC, however i...
13 years agoI'm not sure I understand your problem. What kind of RAM are you using? Is it an external SPI RAM? From your other thread here (http://www.alteraforum.com/forum/showthread.php?t=39915&p=164635#post164635) it doesn't seem to be the case, but in that case why are you connecting it to the SPI component?
