18 years agoByteBlaster II
Hi I hope for some help with a problem I generally use USB Blaster with Quartus II Web Edition V7.1 Build 156 on XP Version 2002 SP3 An coleague has taken my USB Blaster with him on a...
16 years agoI have the same problem with the "Kernel mode driver not installed". I use a laptop hooked to a docking station. The docking station has a parallel port. The docking station requires no drivers at all it just works... so I don't know what driver should I use.
I had windows 7 64 bits and just removed it and installed XP -ONLY- to be able to use my FPGA boards. I have many projects that use old FPGA cards so I need to use the byteblaster cable. With windows 7 I had the same problem with Xilinx, but once I moved to XP all the Xilinx cables (parallel port based) work ok! only Altera brings these problems. Any thoughs on how to make it work?
