18 years agoByteBlaster II
Hi I hope for some help with a problem I generally use USB Blaster with Quartus II Web Edition V7.1 Build 156 on XP Version 2002 SP3 An coleague has taken my USB Blaster with him on a...
16 years agoDoes your motherboard have a parallel port, or are you using a PCI plug-in parallel port? If using a motherboard praallel port you should not have any probelm, as long as it is LPT1:
If the latter, then it will most likely come with another driver - not parport.sys. Parport.sys is the Windows default driver - you should have an installation disk that will put the appropriate XXXXX.sys file into windows/system32 (as I mentioned in my post above). You also need to switch the port number to LPT1:
