18 years agoByteBlaster II
Hi I hope for some help with a problem I generally use USB Blaster with Quartus II Web Edition V7.1 Build 156 on XP Version 2002 SP3 An coleague has taken my USB Blaster with him on a...
16 years ago --- Quote Start --- Hi I hope for some help with a problem I generally use USB Blaster with Quartus II Web Edition V7.1 Build 156 on XP Version 2002 SP3 An coleague has taken my USB Blaster with him on a trip I now tried to install my Byte Blaster II. I have followed the instructions as per below
- Click on the Start menu, and click on control panel.
- Click the switch to classic view link if necessary.
- Double-click the add hardware icon to start the Add Hardware Wizard and click next to continue.
- Select yes, i have already connected the hardware and click next.
- Select add a new hardware device in the Installed hardware list, and click next to continue.
- Select install the hardware that i manually select from a list (advanced) and click next to continue.
- Select sound, video and game controllers, and click next to continue.
- Select have disk ....
- Browse to the win2000.inf file in the \drivers\win2000 directory of your Quartus II software or MAX+PLUS II software installation and click ok.
- Click continue anyway when the Software Installation warning appears.
- Select altera® byteblaster and click next to continue.
- Click next to install the driver.
- Click continue anyway when the Hardware Installation warning appears.
- Click finish in the Completing the Add/Remove Hardware Wizard window.
- Reboot the computer.
