10 years agoByte stream devices is not showing up UP USB BLASTER
Dear all
I have a written a basic hello world code and I build the output I got the .elf output But when I try to download .elf file its giving this error, using cable "usb-blaster [usb-0]", device 1, instanceresetting and pausing target processor: failed
leaving target processor paused when I tried with the ide its self for configuration I can't find the device name in Target configuration section its blank. Kindly notify me what will be error and rectification for it. Thanks in advance, Regards, prasanth
Hi, I have configured it correctly, because the same USB blaster I am dumping my .sof file to the fpga. I am using Stratix V altera in Bittware board.
If the FPGA properly configured and is it getting a clock signal? What hardware are you using? Which FPGA configuration?
