13 years agoByte Enabled RAM Issue
Hi, I am facing an issue while using byte enable memory. My memory is 128-bit wide dual clocked read clock runs at 400MHz while write clock runs at 200MHz Its depth is only 2 ...
13 years agoI'm still not sure I'm getting it. Do you want to read only every other cycle? In that case why don't you use a 200MHz clock and keep the read signal always at 1?
Are the other signals connected to the read port in the 400MHz clock domain?
