13 years agoByte Enabled RAM Issue
Hi, I am facing an issue while using byte enable memory. My memory is 128-bit wide dual clocked read clock runs at 400MHz while write clock runs at 200MHz Its depth is only 2 ...
13 years agoThanks for the reply Daixiwen, I am using EP4SGX230KF40C2 FPGA and the read clock running at 400MHz. Instead of using an alternating signal made using 400MHz, I used 200MHz clock and connected it with the read port. There is no related warning in the TimeQuest report
