13 years agoByte Enabled RAM Issue
Hi, I am facing an issue while using byte enable memory. My memory is 128-bit wide dual clocked read clock runs at 400MHz while write clock runs at 200MHz Its depth is only 2 ...
13 years agoWhat FPGA target are you using? Did you get any critical warning from TimeQuest? I don't really understand what you did on the read port. Are you using a 400MHz clock or 200MHz?
