13 years agoByte Enabled RAM Issue
Hi, I am facing an issue while using byte enable memory. My memory is 128-bit wide dual clocked read clock runs at 400MHz while write clock runs at 200MHz Its depth is only 2 ...
13 years agoI want to add that this behavior varies with build to build i.e. some time RAM works correct. Some time I get a corrupted data at the output and some times no output. Different synthesis results in different outcomes
