13 years agoBUS TOOL Question!
Hi ! I'm using bus tool for the first time and had a bit of a problem. Lets say i have two blocks(Black A and B) consisting of 3 IO. Block A has 3 outputs as of [3..0] and Block B has 3 inputs wh...
13 years agofirst of all.
your name is OK. you don't need name for a bus which connected directory like between inst0 and inst1. also you can name them like "tmp_bus_a_b[3:0]" etc. the last one (Bus[0..11]) just cut off bus and wires. BUS and WIRE can not be connected directory but,each line is connected by there name. see you.
