8 years agoBurn a rpd file on MAX10
I need to provide some interface to a user to download a rpd file into the chip.
So I some questions What format of a rpd-file? byte-sized UTF-8 or may be some extended format like UTF-16? I write with Avalon-MM - it ofers a single word 32-bit (4 bytes) write - so what endianess of a rpd file? First I read all bytes
byte raw_data = File.ReadAllBytes(burn_file_path);
And then I send all bytes over a serial port
for (int i = 0; i < raw_data.Length; i+=4)
word_to_write = (UInt32)((raw_data << 24) | (raw_data << 16) | (raw_data << 8) | raw_data);
msg = WRITE_WORD + " " + word_to_write.ToString();
comport.Write(msg);
progressBarBurnProgress.Value = i;
response = ReadComPort(100, 10);
if (response != ACK)
MessageBox.Show("Wrong response!");
return;
So the question is - this way
or this
word_to_write = (UInt32)((raw_data << 24) | (raw_data << 16) | (raw_data << 8) | raw_data[i);
