15 years agoBug in Quartus II (BDFs + Verilog Parameters)
In Quartus II (11 at the moment, not tried other versions), when updating parameters from within the verilog file and re-creating the symbol file, then updating symbol file in the BDF, the parameters...
15 years agoIf a default parameter value has been overridden in the instantiation, I would not expect a subsequent change of the default parameter value to change the overridden value in the instantiation.
If you are talking about something else, you may need to clarify.
