12 years agoBSP setting for "UDP Offload Example"
Hi, I am modifying the "UDP Offload example" available on Altera wiki for my board(DE2-115) but I got following error while building the project using ./create-this-app command in command mo...
11 years agothere is a couple of changes in the iniche Stack, that's why you get these two populer errors.
You need to disable the file generation for the following files (in the BSP Editor): tk_crnos.h tk_crnos.c targnios.c osportco.c nrmenus.c ipport.h app_ping.h app_ping.c copy the original files that i gave you in your project directory. Jalayan
