13 years agoBSP failure in Altera Monitor Program (AMP)
Dear all, very good day,
I've problem with Altera Monitor Program (AMP), it mentions a failure in updating the settings bsp file. I firstly create the bsp file on commands line, and then this problem happened. What the solution do I update the the bsp file? or what's the way? hypothetically, is there any way that the AMP has missing files? Which by the way I'm using the 11.1 version https://www.alteraforum.com/forum/attachment.php?attachmentid=6859 Pls pls I need an answer if any one has an idea even not experience with this field please share it with us it could be helpful. Thanks in advance to all of you,No RepliesBe the first to reply
