11 years agoBPSK Demodulation
Hello again, I am still struggling with BPSK demodulation :) OK, now I am trying to implement Costas Loop for carrier synchronization, which involves Inphase and Quadrature Phase paths. Inpha...
11 years agothe filter needs to cut off the high sidband.
rf signal has two frequencies at +0.1 and -0.1 when we mix it with 0.1 (or you can choose =-0.1) we get the sum and the difference: 0.1 + 0.1 = 0.2 (high sideband) 0.1 - 0.1 = 0 (our dream dc) the filter must pass dc but cut highband at 0.2 (of Fs) the function fir1 that I used cuts off at 0.3 of Nyquist (i.e. 0.3/2 of Fs = 0.15 so is just right for single tone). bwt this costas loop seems horrible to control compared to my previous work on qpsk/qam which was predictable. in this loop even if reverse the sense of error I get same result. so surely this is not how it should be done. If you make research and find out I will be interested to know. Should we use filter for the error (I tried IIR and IIR + a second accum and lost control).
