11 years agoBPSK Demodulation
Hello again, I am still struggling with BPSK demodulation :) OK, now I am trying to implement Costas Loop for carrier synchronization, which involves Inphase and Quadrature Phase paths. Inpha...
11 years ago --- Quote Start --- Nothing changed also! --- Quote End --- Now what I said should apply but as follows: phy_inc should settle to 0.1, 0.11 and 0.09 for the three cases. I & Q should be dc only in all three cases especially towards end of vector if lock occurs. error may oscillate initially. Do not kill the error by that scaling, you need a target of .01 be added or subtracted from nco value of 0.1 initially. Once the nco is set to this correct value then the error I think will tend to drop towards zero. 200 x 2 does not mean nesting. I simply meant resource of two flters each 200 taps so it 200 x 2 (one per branch) use y = filter(LPF,1,x(1:i)); if it doesn't cut the high band then check response.
