18 years agoBoucing/Ringing seeing on Output pin of Cyclone II FPGA
Hi, I am using Cyclone II to generate a 5MHz clock pulse out from its IO pin and I am seeing ringing problem during the level transition. The overshoot and undershoot could more that 1V on LVTT...
18 years agoThanks for advices. The ringing issue on output pin was reduced to mininum when I set the drive strength to 4mA (degault setting is 24mA).
