MStof1
6 years agoBoard design - how to connect VCC_PGM and does it need to be connected to the configuration memory?
When VCC_PGM is a separate power supply, does that need to be used on the memory connected to the AS_DATA(3:0) pins?
YuanLi_S_Intel
5 years agoHi,
You may find the information such as configuration pin's voltage and connection in our pin connection guidelines user guide.
For cyclone V, it is as attached:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/cyclone-v/pcg-01014.pdf
Thank You
