MStof1
6 years agoBoard design - how to connect VCC_PGM and does it need to be connected to the configuration memory?
When VCC_PGM is a separate power supply, does that need to be used on the memory connected to the AS_DATA(3:0) pins?
YuanLi_S_Intel
5 years agoFor cyclone V, you may refer to pin connection guidelines as shown below for more information:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/cyclone-v/pcg-01014.pdf
MStof1
5 years agoThe pin connection guidelines do NOT indicate anything regarding what voltage should be used for a configuration memory part! There used to be references for older parts regarding that. Apparently, this isn't the case anymore!
