14 years agoBlue Screen while using JTAG
Hi all,
I am new here and need a help. I am working with Altera JTAG device on windows XP using NIOS IDE. Sometimes all works fine but in many cases when i trying to enter debug mode i getting a blue screen :( with an error of: "IRQ_LESS_OR_EQUAL". Does someone familiar with a similar problem? Can someone help please, once it was rare but now its happens a lot and wasting a lot of time. Thanks :), Michael2 Replies
--- Quote Start --- Hi all, I am new here and need a help. I am working with Altera JTAG device on windows XP using NIOS IDE. Sometimes all works fine but in many cases when i trying to enter debug mode i getting a blue screen :( with an error of: "IRQ_LESS_OR_EQUAL". Does someone familiar with a similar problem? Can someone help please, once it was rare but now its happens a lot and wasting a lot of time. Thanks :), Michael --- Quote End --- I get BSODs when using SignalTap once or twice a day. I hit get new data and then BSOD -> Page Fault. This only happens in SignalTap all others tools (and there are some memory intensive ones I use) run fine. Didn't get this in the past on older versions of Quartus on the same machine either. I use Quartus 12.0 Build 178 05/31/2012. I cannot reproduce the error, but it seems that the bigger the SignalTap is (use of internal memory, amount of data watched), the sooner the BSOD occurs. Sometimes I can debug for several iterations (compile, debug, correct, rinse&repeat), today the Tap BSODed me on the first read after starting my PC and Quartus. Gotta ask my boss for an updated license I guess, hopefully the current build is more stable again. - Altera_Forum
I had this issue with my VGA. Same error. No cures :( Anyway, check if You're NOT plugged Your JTAG adapter to USB3 port. Sometimes USB3 doesn't work.
