18 years agoBlockram: RAM model read/write
Hello, Can someone point me out how I can read/write to the following blockram RAM model ? I can read and write to external SRAM, but I am not able to make this work using blockram. Could...
18 years agoI think the polarity is wrong also. Appears that you are sending an active low signal to the internal memory that needs an active high signal.
Put not(Wr_n) to wren and not(Rd_n) to rden and it should be correct polarity.
